Results 1 to 17 of 17
  1. hey,
    i encode my svcd as follows:
    Tmpgenc settings:
    unlock mcf. template
    352x480
    2 pass variable bitrate
    min bitrate 900kb
    max bitrate 1400kb
    avg bitrate 1200kb
    it looks really good, when things arent moving fast or when people are relativley standing in one place or still, but once they start moving, the blockiness is really bad.
    i also burn with nero 5.5 at 12x but i dont think that is the agent causing the blocks. can anyone help me?
    i have a pioneer dv-343 for my dvd player too.
    i know when i used flask, there was a high action or low action way to encode, but im not sure what to do with tmpgenc. there is nothing worse then watching a great porn and then the tits turn into blocks, looks like freaking pitfall from atari 2600...
    (.)(.) thanks!
    thanks!
    Sep 2000
    Northern Virginia
    i think that 1200kbps avg bitrate is a bit low for full vert rez. either scale back to half vert rez (240 vs 480) or crank up the avg bitrate to around 1800-2100kbps...
    <font size=-1>[ This Message was edited by: hitechjunkie on 2001-07-20 11:06:15 ]</font>
    Sep 2000
    Northern Virginia
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    one more thing, make sure the screen is clean from the last time you watched porn -
  4. oh yeah,
    maybe thats what it was
    hmmn. i can up the avg its worth a try.
    i thought dvd quality was 1200 kbs but i cant remember exactly.
    its just really weird that it only happens when things are moving frequently.
    Sep 2000
    Northern Virginia
    i thought dvd quality was 1200 kbs but i cant remember exactly.</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    not even close. dvd quality is probably up around 4500kbps and higher...
  6. plus i use 352x480 because it fits the tv screen perfect.
    i think you might be right, i need to up the avg bitrate because when i did a different svcd, i had the max to like 2400kbs and the avg at like 900 and it still looked the same when it came to blockiness in action scenes.
    the weird thing is , when i upped the min bitrate from 300 to 900 the movie took 5 hours to encode instead of 2 and a half like normal.
  7. what should ideal settings be for a movie to look great keep it on one cd most of the time?
    i like seffy's ideas but i know that they can look even better.
    maybe
    352x480
    min br 1200
    max br 2400 i heard most dvd players cant play over this
    avg br 2000
    would this be kosher or a waste of time?
    Sep 2000
    Northern Virginia
    those settings look good for your 352x480 svcd. you may even be able to get away with min 750, max 2100, avg 1900...
  9. ill give it a try,
    hope the damn blocks smooth out!!!
    thanks chief.
  10. for that res u DONT need 1800+ avg, use 1600 avg 2350max 350min
  11. when its 350 min does it actually drop that low during encoding?
    maybe thats why the blocks are appearing?
    i dont know,
    ill try it too.
    thanks!
  12. yo, don't burn your SVCD at 12X, the safest burning speed for SVCDs is 4x if you want complete compatibility with your standalone dvd player
  13. Not sure if this will make a difference but are you:
    softening block noise
    unchecking "detect scene change"
    I didn't see it mentioned, but it might help.
  14. Since you are watching porn, you can sacrifice the audio bitrate to 64kbit/s, and also use CCE to encode instead of TMPG. Keep the average bitrate around 2000 and you should be fine.
  15. use good quality cd media too. I did same film on a silver cheapo cdr at 4 speed and again on a memorex cdr again at 4 speed. The cheapo cd produced blocks when fast scenes are happening but the memorex hardley a glich .. Experiment with defferant media , but like someone mentioned earlier , use 4 speed to be sure no 14 .
  16. Hi
    Just wondering why the safest speed is 4X as opposed to 2X or 1X?
    Ta
    Furble
  17. yeah,
    i never have tried the block noise feature
    also i use memorex cd-r media, and as far as compatability,
    they have worked no matter what speed i burn at.
    but all these ideas have helped me out,
    thanks for all the tips.
    later!
