  1. Member stackner's Avatar
    Mar 2004
    Digital World, Australia
    how can i extract a motion menu from a dvd? i do not want to extract it as a still image. i want to extract the motion menu so i can re-encode it as divx/xvid i just need to know how to extract it.
    Aug 2004
    Pgcdemux can extract into elementary streams of your motion menu.
  3. Member stackner's Avatar
    Mar 2004
    thank you. however i have already tried this and it will not let me demux/extract the MENU VIDEO. i will try some of my other dvds but the one i am trying to do it shows the motion menu no where. it shows copy warning ect i can extract but not the actual menu....
    Aug 2004
    Do you know which VTS your menu is in? If you do then open the IFO, and did you tick the "menus" part instead of "titles"?
  5. When you play the DVD you see a motion menu? But you can't find it? You know that makes no sense, don't you? A menu is always in a VTS_0X_0.VOB, where X is the number of the VTS. It's often the VTS_01_0.VOB, but not always.
    Tick the Menus Domain, and either PGC, VOB ID, or Single Cell. There's the drop-down box showing all the menus.
