Hey people im having a problem i have 1 8GB DVD+R cd i just bought and i av 4-In-1 film on my computer (so i av 4 films as 1whole)
But i tryed to make the files into a .ISO using WinISO but i kept getting an error message.
So i was wondering how can i make them all into a .iso ready to burn (Plus all 2gther there about 5GB)
Thats just a picture of all my film in the folder.
Please Help.
C
Results 1 to 9 of 9
First, I'm assuming that what you want when you're done is an .iso file that will burn to a viewable DVD? You've already tested the structure/playback?
Anyway, if that's correct, I think the only problem is simply that WinISO doesn't support DVDs, as far as I know. So you just need an iso program that does; my personal preference is UltraISO and you can download a test copy, give that a shot. -
Guide: http://forums.afterdawn.com/thread_view.cfm/383878Originally Posted by Chana1"Art is making something out of nothing and selling it." - Frank Zappa
Thanks ZippyP.
I have another question, well as i said above i bought a 8GB dvd+r disc the other day, i was wondering can i burn like say 2 .iso files about 4gb each on it???
Or does both films have to be in 1??? (on menu screen i would hav 2 choose either 1of the films)
-=Chana=- -
An .iso file is a disk image ... you can only burn 1 .iso to a disk (as the disk image is just that ... an image of a complete disk ... regardless of the size)Originally Posted by Chana1
You must first combine the two movies ... this means you will need to reauthor the two movies into one dvd ... (with a menu if you want to be able to select witch movie to play .... no menu will mean that the second movie will play after the first has completed but you wont be able to select to play only the second movie ... altho you can use the 'next' button on your dvd players remote in order to select it)
If your movies are already in .iso format the use daemon tools to mount the .iso and copy over the actual files to your hdd (do this for both movies)
Reauthor a new dvd using TDA or guifordvdauthor or similar tools
Next use Imgburn to burn to a new dvdr (or you can choose to create a new .iso for burning with other tools)
Help making ISO with ImgBurn
By stantheman1976 in forum Newbie / General discussionsReplies: 6Last Post: 17th Jan 2009, 17:04 -
free software for making cd-rom iso's
By Dr.Gee in forum ComputerReplies: 1Last Post: 27th May 2008, 18:00 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
Making an Iso from an I00 file
By t_jay17 in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2007, 15:50 -
Making My Movies Into ISO File
By imdaman in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2007, 20:06
