Seem to be getting a lot of errors lately when using DVD Shrink and I have been using it for so long I thought it might be a good time to start using another possibly newer tool
Can anyone recommend another newer shareware tool for backing up DVDs and shrinking them to fit on a non dual-layer?
The programs listed are rippers only. I use DVDRebuilder (free version) to shrink DVD backups to single layer. DVDRebuilder does require you to have an encoding program of some kind. I think it works with HC Encoder and I believe that program is free. It actually re-encodes the movie so it should produce higher quality results than DVDShrink, but it will take more time. On average it takes about 4 hours to do everything involved in shrinking a dual layer DVD to single layer.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
DVD Authoring with best passthrough options
By outlawstar223 in forum Authoring (DVD)Replies: 10Last Post: 9th Nov 2010, 13:07 -
DVD Menu Options
By BritGuy79 in forum Newbie / General discussionsReplies: 3Last Post: 20th Mar 2008, 17:47 -
tape to dvd am I using the better options
By pantsdavies in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2007, 12:32 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59
