I have a 90 minute veg file with 60 minutes worth of complex graphics (like moving fractals) in it. Vegas 6 estimates it will take upwards of 7 hours to render the video. Is there some way I can do this piecemeal, maybe split the veg file up?
Results 1 to 10 of 10
use a third party mpeg encoder like cinema craft, mainconcept (standalone) encoder or canopus procoder any one of these will surely speed up your rendering time.
that 1.5Ghz cpu isn't helping things at all either. If you must render such complex video and graphics, a faster PC is a must unless you want to render everything while you sleep at night.
512 MB RAM ? You can barely surf the net with 512MB. You deserve an upgrade.
What are the source file formats and what format are you rendering to?Originally Posted by solarblast
Vegas tends to be very slow as it insists on rendering the whole video not just the transitions.
Your best bet would be to render to DV and then use TMPGEnc or Mainconcept to make an mpeg out of the avi.Regards,
Rob -
If you are generating these effects on the file it will take it's time, especially on your system. If you are doing a 2-pass encode, it will take twice as long. Splitting the file up isn't going to do much to help you.
Best bet - set it going at bedtime, and look at it in the morning.Read my blog here.
I'll be back to look over these posts more carefully tomorrow. However, on the specs, my CPU is 1.67GHz ASUS motherboard with a 1G memory chip.
Sony Vegas 9.0 infinite render time?
By eli_ in forum EditingReplies: 8Last Post: 22nd Aug 2010, 18:51 -
4:3 to 16:9 without reducing quality
By trickytree in forum ffmpegX general discussionReplies: 2Last Post: 3rd Jun 2009, 18:06 -
Reducing filesize
By caper in forum Video ConversionReplies: 19Last Post: 7th Dec 2008, 19:22 -
Reducing frames with Staxrip
By jaysonp in forum Video ConversionReplies: 3Last Post: 4th Mar 2008, 10:32 -
Help with reducing size
By gepetto in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 13:17
