Hi all, I was just wondering if it was possible, in any way, to edit the menu of a foreign film in order to chnage the buttons to english (for example)
sorry I have just seen a post on how to do this, so here is another question...
I have the same movie, one has a foreign language menu and the other has an english, the menus are in the same format, just a diff language... is it possible to swap them? -
Hi-
Yes, it's an easy matter to swap the background menus, assuming they're static. And if the underlying sub_pics are in the same place, you won't have to to anything besides replace the menus from one DVD with the menus from the other. If the sub_pics are different for the 2 DVDs, one in one language and the other in a different language, or in different locations on the screen, then you'll have big problems and you'd best not try. Anyway, here's my guide for this. Scroll down to The Easy Way at the bottom of my first post:
https://forum.videohelp.com/viewtopic.php?p=1606732#1606732
Foreign Language Or Out of Sync Or Both!
By Westie69 in forum Blu-ray RippingReplies: 6Last Post: 8th Oct 2010, 06:35 -
displaying foreign letters
By aruwin in forum ComputerReplies: 5Last Post: 20th Apr 2009, 10:01 -
Ripping Foreign Subtitles in my PC
By devilcoelhodog in forum SubtitleReplies: 3Last Post: 23rd Feb 2009, 09:28 -
spumux menus and buttons alignment
By begemotv2718 in forum Authoring (DVD)Replies: 1Last Post: 3rd Aug 2008, 09:31 -
Menus buttons become assigned to wrong episodes/files
By messiahVx02 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 31st Jan 2008, 02:40
