I don't know what happened but in my network settings I now see an internet gateway denoted. (see first image below).
Right clicking on the gateway and drilling into the settings it seems as though a 'wan' was set up on my machine without my knowledge. (second image below) If I try to disable the gateway and re-establish connection via my local area connection (as it had worked before) I get no network.
What supposed do you think caused this? Do I have to be concerned at all about security? How do you get rid of the gateway so I can have the net card obtain ip via router as it worked (and always worked) in the past?
Looking at the service that is running supporting this gateway (dpnsvr) it seems it is part of Microsquashes DirectPlay feature.... hmmm, how to remove OR maybe don't worry about it since I'm behind a hard/soft firewall.
Thanks in advance.
It might be naughty. Wouldn't hurt to check.
http://vil.nai.com/vil/content/v_128430.htm Click the characteristics tab. -
Thanks .... I'm still digging into it. Lots of pages associated with dpnsvr ... but not associating it with a gateway
This post and thread also provided a resolution for me. The gateway was flipped on via some proggie.
https://forum.videohelp.com/viewtopic.php?p=1663023#1663023
Gateway SigmaTel audio problem
By joecass in forum ComputerReplies: 3Last Post: 12th May 2011, 16:41 -
Change to Gateway/Liteon firmware
By knights89 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 26th Dec 2009, 15:32 -
Gateway LX6810-01 with RCA inputs, how to use?
By Gotmilk0112 in forum Newbie / General discussionsReplies: 6Last Post: 30th Jun 2009, 00:37 -
Securing Wireless Gateway
By Snakebyte1 in forum ComputerReplies: 15Last Post: 3rd Nov 2008, 14:24 -
Kaspersky Internet Security 7.0 installation Conflicting with Internet Exp
By Krelmaneck in forum ComputerReplies: 2Last Post: 5th Oct 2007, 03:36
