This may seem like a bit of dumb question, but I couldn't find anything in the sticky threads to help so I guess I've got to ask.
Basically, I'm trying to rip one episode of a TV series and burn it to DVD, indluding the directors commentary.
I rip it using MacTheRipper Title and Chapter extraction. First time, I ripped it and ignored the whole demux and streams thing. It ends up with just a .Vob file in a VIDEO_TS folder. This Vob, when watched back directly on VLC, lets me change between audio tracks (regular and commentary) as I please. As soon as I burn it, using Toast 8 Titanium, and try to watch it back, the main audio track works fine, but the 2nd one is no longer accesible.
Then I tried ripping it after clicking demux etc and manually selecting the audio streams and subtitles. Again it rips fine- giving me a main folder with 2 AC3 files, and spc file and an m2v file. It also includes an empty Audio_TS folder and a Video_TS video containing a Vob which again plays with two tracks.
At this point, I'm stuck- Toast wont accept the ac3 files, and won't acknoledge that Video_TS folder as a real one. I'm guessing the problem is the lack of .ifo and .bup files may be a problem, but can't work out how to make it happen.
Any ideas?
Ok, Thanks, I'll try that.
I was doing it that way cause I didn't want to rip 12 episodes when I only wanted 1.
I'll try it anyway
Ta -
OopsOriginally Posted by NoDirectionHome1941
sorry I missed that part of your post. Good luck with it!
Toast can only author a video DVD with a single audio track. It does let you select which track (click on the title in the Video window, click the Edit button, choose the audio track by pressing the button next to the audio description.)
The only way to include all audio tracks is to do a full disc extraction and then use Toast's Fit-to-DVD feature (presuming the original DVD is too big for a single-layer disc so that option becomes active). -
That's exactly the answer I was expecting.
Thanks for that though.
Don't suppose you can suggest a program that will allow multiple audio tracks to be authored? -
The only one I'm aware of is DVD Studio Pro.Originally Posted by NoDirectionHome1941
Burn MKV to DVD including 5.1 audio and subtitles ?
By Dinky2 in forum MacReplies: 4Last Post: 11th Jan 2012, 15:29 -
editing with alternate scenes and audio
By }{eywood in forum Authoring (DVD)Replies: 18Last Post: 17th Feb 2011, 03:23 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56 -
How to convert MKV Matroska to Avi or Divx including audio tracks and sub
By s.elmagnifico in forum User guidesReplies: 0Last Post: 16th Aug 2008, 09:47 -
Problems with DVD to VCD, including no audio. Help!
By gastrof in forum Newbie / General discussionsReplies: 8Last Post: 4th Jan 2008, 13:39
