I would like to split a DVD9 image file to 2 DVD5 [the image does not contain any copyrighted material]. I tried to search the forum for guide but could not locate any suitable one.
Please help.
Thank you.
আমি বাংলায় গান গাই
DVD Fab does this and maintains menus etc. You can probably do it with DVD Remake Pro as well. I suspect you can also do it with a combination of PGCEdit and VobBlanker with a little effort. Check out these tools and look at the associated guides for details.
Read my blog here.
You can do it with CloneDVD2. Works fine. A lot easier than VOBlanker. From the guide on the Elby site:
You can make the following selections:
* Title selection: Here you will find a list of all available titles from the original DVD. For each title, you will see the playback time, chapter count and original audio settings (audio tracks and subtitles). You can select one or more titles. Mark the checkbox corresponding to the title/s that you want to backup and the selected titles will be highlighted accordingly
With a click with the right mouse bottom in the title selection you open the following context menu:
o “Select all”: This function selects all of the titles
o “Invert all”: This function inverts your title selection
o “Invert for split”: This function is only activated if you keep the menu. With this option you can invert your chapter and title selection. This is very important if you like to split one DVD over two DVD media!
o “Information”: Opens the context help
* Sorting order: By default, the titles are ordered by playback time. You can change the sorting criteria to title number or chapter count. Simply click on the corresponding column description
* Chapter cutting: You have the possibility to cut off unwanted chapters or to split one movie in two parts. Click on the scissors to open the control element for cutting off unwanted chapters. Another bar appears below the play bar. The small points symbolize the chapters, the space shows the approximate length of each chapter. You can move the blue triangles to cut off unwanted chapters. Either you click on the orange bar to move the blue triangles step by step or you directly drag it to the chapter where you like to have it. The Play Slider above automatically moves to the position of the triangles so that you can watch the first movie scenes from each chapter. The green writing in the preview window shows you the chosen chapter and its play time. On the right hand side, in the title selection, you can see the chapter selection with each title
* Splitting: If you want to copy the whole DVD or you want to copy a movie with extra length, it is advisable to split it over two DVD media. First of all you have to select “preserve menus” for keeping the overview. Via the “chapter cutting” function you can split the main movie in two parts while selecting for example the chapters 1-9 for the first DVD media. Select now further titles like “Special Features” and start the copying process for the first DVD media. When the copying process has finished, please click on the “Back” button until you reach the window with the title selection. Please click with the right mouse button into the title selection dialogue: You can invert your selection for the first DVD media, like in this example, it means that the chapters 10-16 of the main movie and the rest of the titles will be automatically selected
HINT: If you want to split a multi-angle movie, please cut off the same chapters for each camera angle. You can easily recognize titles with different camera angles, as they all have the same playing time!I love children, girl children... about 16-40
W.C. Fields
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 11:37 -
DVD9 to DVD9 1:1 Copy
By Lastman369 in forum DVD RippingReplies: 5Last Post: 12th Jan 2010, 13:48 -
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 19:17 -
Splitting a DVD9 into 2 DVD5's with 100% quality?
By alegator in forum DVD RippingReplies: 10Last Post: 22nd May 2008, 16:10 -
having trouble backing up dvd9 to dvd9
By Chunking in forum DVD RippingReplies: 9Last Post: 13th Oct 2007, 20:34
