  1. Member shaolin2006's Avatar
    Jan 2007
    Help Please does anyone know what video code is needed to open files with the ext. "CBR' What would you use to convert to a workable file format.
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    You sure it's cbr? (You don't have "Hide extension of known file types" enabled, and it's something.cbr.KnownFileExtension?)
    If so, could this be it?
    http://www.filext.com/detaillist.php?extdetail=cbr&Search=Search
    /Mats
  3. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Yeah, the only .cbr extension I know of is usually given to comic book/manga archives, not video (as mats.hogberg's link also mentions). There's a few viewers that can view the archives as virtual comic books, or you can just rename the extensions (.cbr archives are actually .rar archives, .cbz archives are actually .zip archives) and open them as you would a normal archive, to view the images within.
    Apr 2004
    Miskatonic U
    Read my blog here.
