    Feb 2007
    I have a new DVD player. I connected it to a TV with S-Video, Component, composite cables (seperatedly) to test it. S-Video and composite connection works fine, but with component cable, it shows pink on the TV. Does it mean the component output on my DVD player is broken? How can I fix it if it is not? Thanks in advance. cyan301
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Possible bad cable or incorrect menu setting.
    Menu should be set for YPbPr component out and interlace (unless this is a progressive TV).
    To check cable,
    Green to Green (Y) should be monochrome on the TV with all detail.
    Red and Blue cables should add color.
    http://www.kiva.org/about
    Feb 2007
    Thanks, edDV. I think the cable I used is good since it works fine in another machine and I tried more than one component cable, they all are same to show pink color on the TV. I am going to check the menu. Which menu should I look at? TV's or DVD player's? Thanks again.
  4. Member edDV's Avatar
    Mar 2004
    DVD player setup
