  1. Where is the CCE log file? I'm trying to find out how long an encode takes.
  2. Member adam's Avatar
    Sep 2000
    It might depend on which version of CCE you are using, but I believe all versions allow you to specify where the log file gets saved. Look in the options. On my version it is listed under the outputs tab.
