I can only post in the newbie section hopefully it's not the wrong section. I followed this
Guide to the tee. I used all the tools, the original .avi was in two files with .ac3. So I combined the files (virtualdubmod) demuxed the sound, fixed the sound (ac3fix) encoded the avi to mpeg 2 (CCE/AVIsynth), and tried to author a dvd (TMPGenc). The sound is off by at least 10 seconds....... Does anyone know what might have happened, or what I can do now to fix it?? I want to move away from the all in one converters, but I am getting a little lost with the long way. But I will say other than the sound issue I have, the quality does seem to look better than the Nero I have been using. Please someone point me in the right direction, or to another guide that will help me get the sound in sync. Thanks.............
Presumably the sound was in sync in the original avi ?
Was the demuxed audio the same length as the video ? (use something like avicodec/Gspot to look at file properties)
Why did you need to "fix" the audio ? -
Don't join the AVIs before encoding - encode each separately.
Then "join" them implicitly, by adding them to the same track in TDA. If you remove the chapter point TDA inserts at the join, it will play back seamlessly.
/Mats
Mini Guide: Normalizing Audio for Multiple AVI files
By Soopafresh in forum AudioReplies: 456Last Post: 9th Dec 2016, 23:26 -
DVD with Multiple Audio Streams - Basic Guide
By mustang581 in forum User guidesReplies: 29Last Post: 21st Aug 2013, 04:59 -
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
HCbatchGUI user guide ~ Batch process video and audio.
By freebird73717 in forum User guidesReplies: 4Last Post: 21st Dec 2009, 08:51
