  1. Hello,
    I'm using Adobe Premier 6.5. How do I add text in the video that shows up from transparent to visible and back to transparent. Pls help
  2. use the built-in title editor. see the help file to see how this is done. place the text asset in the bin, drag it to video 2 (for example) in your timeline. default duration is 5 sec. right-click on the timeline text asset to change it.
  3. Hello noki,
    Thanks for the reply. What I wanted is to add text that shows up from transparent to visible and back to transparent. The effect I wanted is like fade in and fade out of text. The only effect I see in the titler is stil, roll and crawl. Do you know how to make the fade in and fade out effect of text? Pls help
    Apr 2004
    Miskatonic U
    Create your title, then use fade transitions (or whatever Premiere calls them - it's been so long since I used it) to fade the titles in and out.
    Read my blog here.
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Called a dissolve transition
  6. I used the dissolve transition but the background clip dissolve when the text comes out. I wanted to have a text that fade in and fade out with the background clip as is.
    Also with dissolve, it doesn't fade out slowly. The text abruptly disappear.
    BTW I edit the subject of this post to make clear of what I want on the text. Pls help.
  7. Member edDV's Avatar
    Mar 2004
    BTW I edit the title to make clear of what I want on the text. Pls help.
    Apply the transition to the overlay not that backgroud. Double click the transition and set the duration.
    Buy this: http://www.dummies.com/WileyCDA/DummiesTitle/productCd-0764516442.html
    or this: http://forums.creativecow.net/cgi-bin/new_page_wrapper.cgi?forumid=3&page=http://www.c...6.5/index.html
  8. Finally got it. I didn't use the dissolve. Just expand the overlay track and make the necessary adjustment there. Thanks for all the help.
