I am capturing very high quality MPEG1 files that look great on the PC and encoding them to standard VCD format using TEMPGenc (with some options turned on). The problem is that they become so blocky afterwards (they look terrible on my 27 inch tv). I was wondering if there was a way with TEMPGenc to maybe shrink the output (video size not file size) down so it isn't streched so much and looks less blocky?
reducing the size won't help. when you stretch the video back out it is just like zooming and the blocks will show up.
how are you playing them on your tv? with a standalone dvd player or with a video out card?
With a Sony DVP-NS400D DVD player (great player btw: so far it has taken every cdr I've thrown at it). I just seems like the quality could be so much better. I downloaded the space balls vcd clip from this site that was done with borders or wide screen or something and it looked pretty good. It wasn't strech across the whole screen. I'd almost like to have the same simalar type.
Multiple Files & Resolutions In Tempgenc Xpress 4
By TufrThanu in forum Video ConversionReplies: 0Last Post: 9th Aug 2009, 14:21 -
error while burning DVD DL using tempgenc dvd author
By rgpai9972 in forum Authoring (DVD)Replies: 2Last Post: 2nd Jun 2009, 21:15 -
tempgenc authoring works 4 - can I save the edited clips?
By yvonne_1980 in forum Authoring (DVD)Replies: 2Last Post: 24th Mar 2009, 05:59 -
Tempgenc DVD Author small file
By EPLindblom in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2008, 21:39 -
problem with tempgenc plus
By lancerx in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2007, 01:35
