Hi,
I had a avi Divx4 (Open Divx), according to Gsopt.
I used the programa AVI FourCC Changer 1.00 to change the codec and see if I could work with it better, because I had problems to demux the audio ac3 that didn't play well.
The problem now is I can't go back and have the avi as it was originally.
I have this film in two halves. The first one is unchanged (Divx4 Open Divx) and I can see the image, the second one was changed with AVI FourCC Changer and I can't see it any more. This program has the options Fourcc description code and user code but I can't choose the right one as to let the avi with the Divx4 (Open Divx) as it was at the beginning..
Thanks in advance.
Well,
I found a solution. I downloaded a different program, AVI 4CC Editor, and this one let me choose the right codec.
Now I still can't demux the audio ac3 from this avi Divx4, nor can I reencode the avi outputting an audio that works. -
All you had to do was look at the unmodified file to see what the two codes are, then restore the modified file to those same codes.
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Restore original region code
By samirala in forum DVD & Blu-ray PlayersReplies: 5Last Post: 5th Jan 2011, 13:00 -
hard copy subs without changing codec fast
By Ceesar in forum SubtitleReplies: 15Last Post: 21st Oct 2010, 10:38 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41
