Is it possible to have delay in AVI-files like those in DVDs and if so, how do I check what delay my files have?
I'm having problems with meGUI.
I've been re-encoding some music videos into iPod-compatible MP4/AVC now and certain of these go offsync. And I'm not talking about the kind of offsync where it's synced at first and then go increasingly offsync as time goes on. It's offsync from the start.
However, encoding the same files in Elecard Converter Studio will give me a file with perfect sync (or so it seems at least).
Why is this? Is it because of delay? Is it possible for AVI-files to have delays like the ones on DVDs? Is this why it's going offsync because meGUI cannot recognize delay and adjust accordingly?
If it's because of delay, how do I check the delay? Neither G-spot or MediaInfo will tell me what delay (if any) the files have. Or is it something else entirely?
Test your AVI files out with this:
https://forum.videohelp.com/viewtopic.php?t=321684
See if the remuxed with WAV files are in sync. If they are, feed them to Megui. -
And if they aren't (it's still offsync)? >_>
I still need a way to check the delay of a file. What if a certain file's got just enough delay to not be very noticeable? I don't feel like using AVI Prep on every single file I have before encoding them <_<'.
Also, it took, like, 10 minutes to do a 4-minute music video. Of course, it was 125 meg large, but I don't want to think about how long it'd take to do a 2 hour 1.4 gig file. Checking the delay and adjusting the output accordingly is faster and easier.
But is it even possible? -
That probably means the audio sample rate is influencing the length of the audio file. Once your audio track gets resampled to 48000Hz, the length is no longer the same as the original.
for testing purposes, you can change the Avi_Prep.bat file from
ssrc_hp --rate 48000 --bits 16 --dither 1 --pdf 1 1 x-gain.wav a-gain.wav
to
ssrc_hp --rate 44100 --bits 16 --dither 1 --pdf 1 1 x-gain.wav a-gain.wav
Just run one file through. Does the resulting file stay in sync ?
You can determine sync values while playing your AVI in MediaPlayerClassic
Keep changing the value while the video is playing - you probably won't need more than -1500 to 1500 ms -
Hi again.
Where in this should I insert the SSRC(44100)-code?
DirectShowSource("C:\United KIngdom.avi",fps=29.97000002997,audio=false)
#Not doing anything because the source is progressive
#crop
BilinearResize(320,240) # Bilinear (Soft)
#denoise
BTW, the output file is AAC CBR.
Txmuxer automatically selecting audio delay when reading BDMV files
By Odaik in forum Video ConversionReplies: 2Last Post: 12th Jul 2011, 12:28 -
Splitting VOB files with audio delay/quality loss?
By S0VIET in forum Authoring (DVD)Replies: 8Last Post: 30th Oct 2010, 22:48 -
how to solve audio delay in WMV files?
By sumeshkri in forum Video ConversionReplies: 2Last Post: 3rd Nov 2008, 22:54 -
Joining MPEG2 files with different AC3 audio delay on each file
By Killer3737 in forum EditingReplies: 6Last Post: 28th Oct 2008, 00:32 -
RM to AVI image delay
By cedboe in forum ffmpegX general discussionReplies: 2Last Post: 27th Jul 2008, 23:54
