When I edit mpeg files (by cutting selections) with avidemux, I set audio and video to copy and the format to mpeg PS. When I save the file I get a popup about encoding. Am I losing quality because the program is re-encoding the file? Is this the wrong tool to use to cut sections of mpeg files? I also get the same when I load VOB files.
Thanks for any information,
Steve
I am running Ubuntu Edgy which looks like it uses version 2.1.2 (I'm looking at the package list from their web site since I'm not home right now).
Are you saying you don't see the encoding popup when you save? What popup do you see (if any)? Also do you save to the same file (File->Save) or to another file (File->Save As)?
I'm not sure if I'm losing quality, I'm more concerned because of the information on the popup which implies re-encoding.
Finally, can I tell by how long the process takes? This is a four minute clip (about 600mb) and the saving takes < 1 minute.
Thanks,
Steve -
I just double check it just now. I get a pop-up that say encoding. When I compare the results using xine.
The only difference is the bit rate. I dont see any other difference. But I agre why is it even doing that.
The resulting video clip dosn't look any difference than the orignal.
As far as time to save a 19:37 min video clips take 1:14 to save.
Avidemux .. editing AVI h264
By rogerer in forum EditingReplies: 2Last Post: 3rd Nov 2011, 12:43 -
editing Quicktime with avidemux
By pooksahib in forum Video ConversionReplies: 2Last Post: 8th Sep 2011, 07:53 -
Avidemux MKV editing problem
By FatalX in forum EditingReplies: 6Last Post: 20th Sep 2009, 21:02 -
editing Avidemux
By Orion12345 in forum EditingReplies: 16Last Post: 18th Aug 2009, 04:12 -
Editing with Avidemux
By DaneClark in forum EditingReplies: 1Last Post: 11th Jul 2009, 09:27
