    Feb 2007
    Woodland Hills, CA, USA
    I have 3 .vob files from a DVD, all copied, decrypted and in a folder on my hard drive. Two of the files will convert to .vob.ff.mov files that I can edit in Final Cut Pro. (By the way, before anyone brings it up, there are no copyright issues - it's material I own and had shot on mini-dv, transferred to DVD because I don't have routine access to mini-dv for editing.) One of the files won't convert properly. It acts as if it has converted in about 5 seconds, but the resulting file shows 0 bytes on the hard drive. As for the integrity of the .vob file, I can play it in the preview function of ffmpegX 0.0.9x. Any suggestions?
    Thanks...
    Brad
    Feb 2007
    I am having the exact same problem. Have you resolved it yet? If so it would be great to hear what your work around was.
    Thanks in advance.
    -R
