I just did a clean install of the latest version of ffmpegx on my 10.3.9 machine - I followed the instructions on the download page, but at no point did a registration page appear. tried running ffmpegx, it runs, but I'm still, obviously, locked out of the tools that require registration.
how do I enter my registration keys?
problem solved.
for anyone else running into this problem, here's some tips that might help.
1. follow the instructions as per the download page which will step you through getting ffmpegx installed in your Applications folder
2. unmount the ffmpegx disk image! the one that you mounted to do the installmake sure you unmount it!
3. just to be safe, unmount any other external drives that might have an old copy of ffmpegx
4. make sure ffmpegx is not still running from step 1. go back to the Application folder and run it a second time. the registration screen should drop down
worked for me!
hope that helps the next newb
web page translator and email full page translator
By juststarting in forum ComputerReplies: 3Last Post: 1st Feb 2010, 09:23 -
ffmpegX splash screen still showing after registration
By Le Main Event in forum ffmpegX general discussionReplies: 2Last Post: 2nd Apr 2009, 10:11 -
ffmpegX registration key
By lyndb in forum ffmpegX general discussionReplies: 2Last Post: 28th Nov 2008, 18:16 -
Cant register
By eddier528 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th Jan 2008, 03:33 -
Can't register
By gussi86 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Oct 2007, 09:33
