I have a Sony Bravia HDTV with a CI slot for receiving Pay TV terrestrial television. I just bought a Pioneer DVR which also has a CI slot. I have asked the Pay TV smart card provider where they think I am best off putting the card; in the HDTV or the DVR, but I keep getting different answers from them.
What do you guys think?
	If it has to be one, the DVR can't record without it. If you can get a second card (seems fair to me), you can watch something else at the TV. Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	A CI slot is not enough to use your HDTV card, you also need a
 CA Module specific for the type of encryption/decryption used by the provider.
 Take a look at this page for a better view:
 http://www.hauppauge.nu/pages/products/eng_1prod_data_ci.htmlNo tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. ..
	I do have CAM for both appliances, and the DVR has a built in tuner.
 So did I understand you right, should I choose to put the card in the DVR?
	The DVR can feed the TV. Can the TV feed the DVR? It depends on the TV hardware capability and how you want to use it.Originally Posted by santamonica
	Yes, the TV can feed the DVR (when the smart card is in the TV CAM).
 So now, does that make a difference in the choice of where to put the smart card?
	Try it both ways and see which works for you.
 Seems to me the DVR needs to tune the channels if you want unattended recording.
  Smart TV Tuner card and ps2By neko_chan in forum Media Center PC / MediaCentersReplies: 3Last Post: 27th Apr 2009, 04:09
  Video Card To HDTV Help with DVRBy sammyv in forum Capturing and VCRReplies: 3Last Post: 12th Dec 2008, 18:42
  Using PC as DVR for HDTVBy moviegeek71 in forum Media Center PC / MediaCentersReplies: 0Last Post: 2nd Nov 2008, 17:05
  Need al little help getting my new ati hdtv pci card to sense HDTV channelsBy MidnightMike in forum ComputerReplies: 8Last Post: 23rd Jul 2008, 03:12
  HDTV DVR hookupBy mandy79 in forum DVB / IPTVReplies: 4Last Post: 12th Dec 2007, 14:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
