My usb modem disconnects when I connect my Creative ZEN V mp3 player, I tried to connect the mp3 player in first then the modem but it just doesnt dial up.
Is there anyway round this?
Would connecting a usb hub work?
Are either powered by the computer? If so a powered hub might help. USB is limited on how much power it can deliver. Try to overload it, and it will just kill that channel.
But you might be better off to just install a PCI USB card, just in case it's a address or data interference problem. In this case a hub wouldn't help as it would still be using the same channel. Have you tried other USB sockets on the computer? You should have more than one channel available. -
I dont have the installation cd for that mp3 player and when the found new hardware popped up it trys to search the internet for the drivers but by then the internet has just disconnected
Ahhh...
Try a powered hub first. Unless neither units use laptop power. Then it might be some sort of USB conflict.
You could look in Control Panel>System>Hardware>Device Manager>Universal Serial Bus controllers'. Look in the USB 2.0 Root Hub>Properties>Power Management'. You may see this box checked ' Allow the computer to turn off this device to save power'. That's one possibility, power related. You may have more 'Root Hub's with the same settings. Laptops are fairly limited for USB power.
But a powered hub may fix that.
I would go to the MP3 players website and see if you can DL the drivers from them, without the device plugged in. Usually USB devices don't need drivers with XP, only with W98. But it may be more than just the driver it needs. If you find the right drivers and programs on their site, that might cure it. -
DEf usb power ... I use to get the same thing when I turned my USb printer on..Its mains powered but it still caused my Usb modem to disconnect and power off...VIA chipset??
thanks for the answers, im going to buy a powered hub now and try it.
Internet Continously Disconnects
By imdaman in forum ComputerReplies: 13Last Post: 26th Mar 2010, 16:39 -
Router for USB Cell Modem
By Poppa_Meth in forum ComputerReplies: 3Last Post: 11th Jun 2009, 19:02 -
Are there usb speaker docks available for all mp3 players?
By yoda313 in forum ComputerReplies: 1Last Post: 23rd Feb 2008, 15:50 -
Can a usb mass storage mp3 player and usb harddrive coexist in vista?
By yoda313 in forum Off topicReplies: 3Last Post: 5th Aug 2007, 18:23 -
Using 500GB usb drive as player on Standalone with USB
By OdubruS in forum DVD & Blu-ray PlayersReplies: 5Last Post: 26th Jul 2007, 05:36
