I captured a 3 hour movie and the result was almost 9 gigs with stereo ac3. I used dvdshrink to take it down to 7.9 gigs. I tried to burn it using recordnow deluxe but I keep getting "a formatting error in the audio_ts/Video_ts folders" error. I tried the trick where you use dvdremake pro to add a split,but the result from that won't play. I press play in windvd and it stops immeditatly after I press play. Is it when I used dvdshrink that messed it up or is it just that Recordnow is being picky?I also should mention that I authored it without a menu,so it would play as soon as inserted. Anyway I can fix this and get recordnow to burn it with no problems? thanks
What did you use to author it with? Did it play properly after processing through Shrink, before you burned it? If so, I would try ImgBurn, especially if you are burning DL discs. And I assume you are using Verbatim DL+ discs?
Or did you split it up to fit on 2 single layer discs after running through Shrink? I would have split it first while it is a MPEG in that case, then authored the two parts before Shrinking.
There's probably a reason, but capturing it with the proper bitrate would have been a lot easier.
Problem Playing Authored/Burned Dvd on DVD Player
By djgazzabhoy in forum Video ConversionReplies: 10Last Post: 24th Nov 2011, 14:15 -
fast forwarding authored DVD causes sync problem
By snafubaby in forum Authoring (DVD)Replies: 3Last Post: 15th Feb 2010, 00:10 -
Samsung BP3600 problem playing Nero authored DVD's
By stonejg in forum DVD & Blu-ray PlayersReplies: 6Last Post: 10th Jan 2010, 12:56 -
Lipsync-problem with copy of authored DVD (TMPG-related)
By fedet123 in forum Authoring (DVD)Replies: 2Last Post: 10th Oct 2009, 19:01 -
burning and authored mpeg to dvd?
By just in forum Newbie / General discussionsReplies: 21Last Post: 12th Dec 2008, 09:06
