I have been playing around with Divx Author and I know that Tmpgenc worked with Divx to design the program. I have been using the text effects quite abit and I am wondering if the Bevel Function actually does anything. Whenever I apply it, the text seems unchanged. Adding borders, shadows, ect., bring noticable changes.
I am curious what others think of the bevel function. I think Bevels are suppose to bring a 3D Effect to the letters.
Thanks in advance for any information you can give me on this topic.
The bevel effect works for me, but I must admit that it's not the best bevel effect I've seen. You can't change the color of the bevel effect, and there's no shadow to the bevel, only highlights. If you're using it on a white or light colored background (or have white text), then that might be the reason you can't see it.
You may also not be able to see it if the "Size" value is set too high. Set the size to a lower value and you should be able to see the effect. -
gyoshi: Thank you for responding to my question. It was kind of you to take the time to share this information.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
Sound turned to white noise when using TMPGEnc Xpress & DVD Author
By Hal05154 in forum Authoring (DVD)Replies: 4Last Post: 15th Jan 2009, 23:03 -
Help.... Conversion & Author Problem with TMPGENC Xpress V.4.4.1.237
By milindb1 in forum Video ConversionReplies: 19Last Post: 22nd Sep 2008, 03:40 -
TMPGEnc DVD Author 3 & Overscan
By heyjjjaded in forum Authoring (DVD)Replies: 4Last Post: 11th Aug 2008, 02:24 -
TMPGEnc DVD Author & Dolby 5.1 Digital Sound - Can it be Done??????
By Sparehead01 in forum EditingReplies: 2Last Post: 28th Dec 2007, 15:53
