  1. I have a mpg2 file that I would like to change the bitrate and the size (number of pixel)
    I try to convert it using tmpgenc but it tell me that the file is not recognizable.
    Is it possible to convert mpg2 to mpg2 using this software ?
    thanx
    Tmpgenc plus should support mpeg2. Have you tried change the directshow source reader? www.videohelp.com/tmpgenc#problems . Older tmpgenc version required a mpeg2 decoder like powerdvd installed to be able to import mpeg2. You can also try the TMPGEnc MPEG2 Plugin.
    or are you using tmpgenc xpress?
  3. I have tmpgenc plus version 2.5
    the direct show multimedia file reader is already at the top of the list in the VFAPI plug-in
    Ulead DVD Player is already installed on that computer
    I will try the pluggin that you recommend and see it its work
    should I use tmpgenc xpress, is it better ?
    thanx for the help
    Apr 2004
    Miskatonic U
    Open the file in G-Spot 2.60Beta or later and post a screen shot here.
    Read my blog here.
  5. Your pluggin work fine
    thanx a lot !
