I took out my factory usb card out and replace it with a 2.0. How can i get it to burn faster than .5 the speed? I am using a HP burner and pc.
DON'T GIVE UP
Did you uninstall the drivers and allow windows to load USB2.0 drivers?
Is your burner USB2.0?
Does your burner actually support the maximum rated speed on your media?
If there is not a 16x write strategy for a given media in the drive firmware it will burn at 8x, or 4x or even 2.4x.
Have you updated your drive firmware?
Since you have not identified the mediaID for what you are burning, you will only get vague responses.
In checking the HP DC4000 you list in your config it is an 8x drive. If you are trying to burn at 16x, it won't.
AverTV USB HD DVR or Hauppauge USB HD PVR
By gll99 in forum Capturing and VCRReplies: 34Last Post: 8th Jun 2015, 09:56 -
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 16:03 -
Question about deleting USB drivers to fix lack of USB notification
By jimdagys in forum ComputerReplies: 13Last Post: 15th May 2010, 10:24 -
Cinergy 400 USB & pcmcia»USB 2.0 difficulties
By AEN007 in forum Capturing and VCRReplies: 0Last Post: 4th Mar 2009, 01:21 -
Can a usb mass storage mp3 player and usb harddrive coexist in vista?
By yoda313 in forum Off topicReplies: 3Last Post: 5th Aug 2007, 18:23
