    Jan 2005
    hi, i have a pretty standard keyboard with an exception that above the f1-f8 keys, i have these optional keys such as : stop, play, internet, media player, calculator ...etc i was wondering if there was a way to change what the buttons trigger on my computer. For example, right now if i press the "media" button, windows media player pops up, would there a be a way to change the factory default to say.. something like winamp?? thanks for your help.
    ps. my keyboard had no manual.
    USA
    Probably. You must have a program somewhere in the computer that is mapping those keys to those functions. I would look for it first. Or if it's an aftermarket keyboard, look on the bottom for the manufacturer and check their website for a program.
    All the ones I have used with those sort of keys came with a disk or floppy with the program on it, that should also be available from the manufacturer.
  3. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    Also, you could try Start->Setting->Control Panel->Keyboard then Buttons tab. Look for the amdeia button. On my keyboard I don't have a media button, but I do have a cd/dvd burn button, and under the keyboard buttons tab I have the option to change it to any program of my choice. So maybe you'll have these same options for the media button.
    What We Do In Life, Echoes In Eternity....
