Hi all-
I'm a classroom teacher and am accumulating more and more original footage (avis) that are taking up too much space on my HD. Is there a way/file type that would allow me to compress these and have them still editable (in MovieMaker or similar that requires avi format) at some later date?
Many thanks,
Mark
Results 1 to 11 of 11
You can convert to avi divx/xvid using for example AutoGK or wmv using Windows Movie Maker and those will be editable in moviemaker. But you will lose video quality best would be to keep them as DV.
Interlace MPeg2 is a less destructive intermediate step. MPeg2 can be edited. Hand held DV is difficult to compress with quality.
Mpeg2 may not be the best choice for editing. It is possible but it's problematic.
Even a broken clock is right twice a day. -
Not as good as DV or all I frame MPeg2 but he said he wanted to compress.Originally Posted by Nitemare
Buy some external and/or removable hard drives and export to them, keeping the DV-AVI format. Divx/xvid and Mpeg2 are OK for simple editing, but I assume you want these clips for future students to work with and you'll want to be able to offer them the best starting point possible for their creative projects.
Buy My Books -
Proper drive preference settings can get all your temp files for your project on the external drive along with the primary imported bin files. This allows you to reload the project at a later time and continue editing without having to re-render all the effects and filters. I still keep source video/graphics/audio files and an edit master on tape/DVDR separate from the hard drive as backups.Originally Posted by guns1inger
How to compress videofiles?
By BigDrago in forum Video ConversionReplies: 11Last Post: 9th Aug 2011, 12:00 -
Do I need to Compress the Data?
By Seanna in forum MacReplies: 10Last Post: 17th Mar 2010, 13:32 -
How to compress DV avi
By marti252 in forum Video ConversionReplies: 12Last Post: 7th Dec 2009, 02:12 -
compress video
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 4th Dec 2009, 03:43 -
Can i compress a
By YOURCONNEXX in forum Video ConversionReplies: 4Last Post: 9th Dec 2007, 12:03
