    Dec 2001
    surrey, b.c
    Hey, anyone familiar wit 3d max and Flash? I know there are some peeps out there that know this iish. But I was wonderin, if you can put some of your 3d max animations in flash? please me!!
    uneek, is a unique way of spelling it.
  2. there are a coupla plugins you can try, the first is illustrate! www.david-gould.com or vecta3d max www.vecta3d.com which will let you render your max scenes straight to a swf file
    Fallen Angels Live Life Expecting Nothing
    Dec 2001
    surrey, b.c
    well, is there another plug-in that's free?? ehehheee...
  4. i dont thinkso, sorry. you can always import your movie as an avi into flash, and then use 'trace bitmap' fpr each frame, though this can be a bit labourious
