Im making a disk with 3 mpg's.
1) The Intro menu I made
2) The Movie It self
3) And another mpg that says "Please insert next disk"
My prob is it wont show the last part. I tried doing a small video but it only plays half of it know matter howw long I made it. I also tried loading a .jpg into TMPG and convereting it to mpg but when I do that it just shows track 3 as a black screen. Am I doing something wrong???
Thanx
Results 1 to 16 of 16
Just how exactly did you make that last MPEG?
And what are you using to author your VCD?
Regards.Michael Tam
w: Morsels of Evidence -
I used Swish to make it then saved it to avi then converted it to mpg. I also made a still image in PSP then used TMPEG to convert it to mpg.
Im using cdrwin. -
So that last MPEG is encoded with TMPGEnc? How long is it (> 4 seconds)?
Furthermore, did you use the default VCD settings in TMPGEnc?
Regards.Michael Tam
No I encode everything with SeVCD. The video in question was 10sec. then I did a still that was 1sec.
Thanx -
Okay, you haven't given me the answer that I need...
MPEG number 3 (your last one which isn't playing properly) -- how was that made (step by step)? How long is it?
Regards.Michael Tam
It was made by me using Swish(Like macromedia flash), I then saved the file as an avi, then I converted it to mpg w/ TMPEG using the SeVCD tamplete(NTSCFilm).
This is the same way I did the first of the 3 which works fine.
I also made a picture in PSP then used encoded w/ TMPG using normal VCD templete.
Thanx for all your help thus far and if im leving out anything please let me know.
Thanx again -
Also the 10sec. vid will only play for half of the lengh of the video. And the still image only shows a black screen.
Okay.
What I don't understand is exactly how that picture you made relates to MPEG #3...
Regards.Michael Tam
The picture I made with PSP, I then loaded the .jpg into TMPEg and encoded it to an MPG, I thought thats how you get a still image to work as a menu??
Ahh.....
Here is your problem... MPEG stills are in fact, not created in this fashion.
Try this:
http://www.geocities.com/medinotes/vcd/mpeg_still_images.html
http://www.vcdimager.org/guides/mpeg_still_images.html (mirror)
Follow the link to mikk's site for details on how to make it.
Regards.Michael Tam
I dont know If the way I did it is the best way but what I did is took a still jpg and when encoding it a added a 5sec silent track as the audio and now it works here s my xml if you see away I can do this any other way.
Code:<?xml version="1.0"?> <!DOCTYPE videocd PUBLIC "-//GNU//DTD VideoCD//EN" "http://www.gnu.org/software/vcdimager/videocd.dtd"> <videocd xmlns="http://www.gnu.org/software/vcdimager/1.0/" class="vcd" version="2.0"> <info> <album-id></album-id> <volume-count>1</volume-count> <volume-number>1</volume-number> <restriction>0</restriction> </info> <pvd> <volume-id>VIDEOCD</volume-id> <system-id>CD-RTOS CD-BRIDGE</system-id> <application-id></application-id> <preparer-id/> <publisher-id/> </pvd> <sequence-items> <sequence-item src="intro.mpg" id="sequence-00"/> <sequence-item src="plane.mpg" id="sequence-01"/> <sequence-item src="nextdisk.mpg" id="sequence-02"/> </sequence-items> <pbc> <playlist id="lid-000"> <next ref="lid-001"/> <return ref="lid-end"/> <wait>-1</wait> <autowait>0</autowait> <play-item ref="sequence-00"/> </playlist> <playlist id="lid-001"> <prev ref="lid-000"/> <next ref="lid-002"/> <return ref="lid-end"/> <wait>5</wait> <autowait>0</autowait> <play-item ref="sequence-01"/> </playlist> <playlist id="lid-002"> <prev ref="lid-001"/> <next ref="lid-end"/> <return ref="lid-end"/> <wait>-1</wait> <autowait>0</autowait> <play-item ref="sequence-02"/> </playlist> <endlist id="lid-end" rejected="true"/> </pbc> </videocd>
To put up a still image, follow the links I gave you before...
You need to put the still image in the <segment-item> and you don't need to make a dummy audio file.
Regards.Michael Tam
some will play and some wont.
By kushy66 in forum Newbie / General discussionsReplies: 9Last Post: 22nd Aug 2011, 21:32 -
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 05:15 -
xp wont play movie
By natty in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2010, 12:26 -
8x DL wont play in PS3
By Onceler2 in forum MediaReplies: 3Last Post: 6th Aug 2009, 14:16 -
WMP11 wont play some MKV files-problem (choppy audio output only)
By deejay.2001 in forum Software PlayingReplies: 4Last Post: 31st Jul 2009, 07:09
