Just bought a 'pre-furb' PC for the mother-in-law and installed Windows 2000 on it.
Getting stuff like Office etc installed and noticed that whenever any file is deleted, it's really deleted. Nothing is going to the Recycle Bin!!
Can anybody gimme a clue as to what the problem is here?
The mother-in-law is very technologically challenged -- I don't want her accidentally deleting important stuff and not being able to restore it.
TIA!!!
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
right click recycle bin
select properties
select global
deselect Do Not Move Deleted Files to the Recycle Bin -
nope, that's not it.
I checked it and the option to "Do not move files to the Recycle Bin." is not checked.
I even marked it, applied the setting, and then un-marked it and applied the setting to really make sure that the option was not set.
Stuff is still getting deleted without going to Recycle."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
in fact, even if I drag a desktop item to the recycle bin and drop it on there, it asks if I want to delete the item (as opposed to sending to recycle) and once I choose yes, it's gone.
dragging stuff to the recycle bin and then exploring the recycle bin, I find an empty recycler."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
What kind of importan stuff are you worried about her deleting? Docs? System Files?
Nothing can stop me now, 'cause I don't care anymore. -
Yes and yes.
Like I said, she's VERY technologically challenged.
In her 50's and this will be her first computer since the days of the Apple IIe."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
Your best bet will probably be to create a basic user account for her and lock it down in User Management so she can't do much other than run apps.
vdub - bad PCM audio capture after fresh install of huffyuv
By wolfdogg in forum Video ConversionReplies: 1Last Post: 11th May 2011, 01:45 -
Recycle Trash bin
By bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 26th Apr 2009, 14:11 -
recover files from recycle bin
By Tbag in forum ComputerReplies: 5Last Post: 25th Jul 2008, 08:16 -
Codecs - Which to install on fresh OS?
By acommuter in forum Newbie / General discussionsReplies: 9Last Post: 7th Jul 2007, 17:39 -
recycle bin errors
By piano632 in forum ComputerReplies: 11Last Post: 29th May 2007, 10:33
