My parents have 2 cyberhome ch-300S recorders.
One is mfg date march 2004 10s bios and it gets confused a LOT LOL
The other is mfg date march 2006 bios V10 and its great.
I tried to go to cyberhome and dl a new bios for the old one but
cyberhome is NO MORE
is there anywhere I can get an updated firmware for the old unit?
thanks big time for any help
Results 1 to 11 of 11
You might want to try the CYBERHOME forum at the nerd-out website.
http://www.nerd-out.com/
Good Luck !!!
From what I found over there it doesn't seem that there was any upgrades released for the 300s.
sad thing they were a good cheap unit.
oh well time for a new one.
thanks big time for the link -
If it gets "CONFUSED" a lot, it's probably because the laser reader is getting dirty. Happened to my Cyberhome, and my Sanyo as well. My Sanyo was still under warranty, so I sent it back. Cyberhome I had to open up the box and clean w/ Alcohol + Qtip. Works much better now.
Scott -
If you are looking for a new and inexpensive DVD recorder then you might want to check out the Magnavox MWR10D6 which can be bought at WALMART for $98.87
I am not saying that this is the "greatest" DVD recorder out there but it probably is the "best" of the inexpensive DVD recorders.
However if you have the money ... the two best models out there right now are the Pioneer DVR-640H-s and the Toshiba RD-XS35 ... the only bad thing is the price. Both models are over $300 and to get the best price you have to go mail-order (try a website like PRICEGRABBER.COM for the best price).
Or try froogle.com (froogle.google.com).
The Pioneer - http://froogle.google.com/froogle?q=Pioneer+DVR-640H&btnG=Search+Froogle&lmode=online&scoring=p
The Toshiba - http://froogle.google.com/froogle?q=Toshiba+RD-XS35&btnG=Search&lmode=online&scoring=p
I'd also suggest looking into the reputation of any retailer you come across that is unknown..A good one to try - resellerratings.com -
i have the cyberhome DVD320 and when i go the cyberhome website it shows its for sale and i can access anything cause i was looking for a firmware update. anyone know anything?
They are out of business. As in GONE ... outta here ... no more.Originally Posted by rubberman
Your best bet for info including firmware etc. would be the nerd-out forums. (see my earlier post in this thread).
the 320 i have is a good player. hell it even played more copied DVDs than the $200 toshiba i had.
I just bought the Magnavox MWR10D6 but having problems connecting it in line with another vcr player inorder to record family videos to dvd, any suggestions?
Regards, -
What do you mean you are having problems connecting the VHS VCR?
You need to be more specific although there really isn't much to it. Just connect the VCR to one of the inputs and be sure you have the correct input set to "on" on the DVD recorder.
Also be sure to use the A/V out of the VHS VCR ... do NOT use the RF output of the VHS VCR.
Need firmware for CyberHome DVR-1200 (MU)
By Man In Black in forum DVD & Blu-ray RecordersReplies: 7Last Post: 25th Jul 2009, 21:46 -
Where to Get Firmware Update
By Teac23 in forum ComputerReplies: 1Last Post: 26th Apr 2009, 13:52 -
Cyberhome DVR1600ME2 firmware
By DogDoor in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Jun 2008, 15:45 -
DVP642 - Did they ever update the Firmware?
By kelemvor in forum DVD & Blu-ray PlayersReplies: 3Last Post: 21st May 2008, 08:50 -
update firmware
By avextraxjp in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2008, 22:46
