does anyone know the universal remote code on this model?(ilodvdro4) di lost my orignal universal remote and cannot seemed to find a code that works on my new one(after trying 3),so i can t even use the stupid thing,any help would be great,thanks rallen52@gmail.com
Check out the fourms at
http://www.remotecentral.com/cgi-bin/mboard/forums.cgi
If you have a one for all remote, the manufacturer is pretty prompt in responding to such requests by email and advising you whether your remote will work with the item and offer suggestions for making things work. -
There's a sticky on replacing the iLo remote here:
http://www.techolio.com/forums/phpBB2/viewforum.php?f=7&sid=9fc98c3f81dd29a32b3f363baaeebc91 -
rallen52
I have a number ilo units
Bottom Line there are no codes available and none are or will be provided.
A learning remote can be used but I have yet to see one that has all functions on the correct button
The techolio site given is a good one and covers much --- But
Do yourself a favor and get an original while you can for $13
Here
http://store.litetrek.com/index.html
Even if you use a learning remote [as Ido for some functions]
Get an Original
Remote code for Memorex MVD2016 needed
By ravenswd in forum Newbie / General discussionsReplies: 1Last Post: 23rd Feb 2011, 17:47 -
RJTech DVD Player Remote Code
By The Monkees in forum DVD & Blu-ray PlayersReplies: 0Last Post: 17th Apr 2010, 17:08 -
Where to find universal remote code for Philips DVP5990/37?
By FredThompson in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Mar 2009, 11:14 -
Remote code for LG LRH-880
By roberthouben in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Feb 2008, 12:41 -
VLC Player - Code Needed For Remote
By John_Jordan in forum ProgrammingReplies: 2Last Post: 15th Jan 2008, 22:13
