Results 1 to 9 of 9
    Feb 2007
    On Earth!!
    Hi, it might be wired question, but cant stop to asking here.
    Recently heard about satellite channels, using some kind of card to watch world satellites and channels.
    Need information on this.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    do a search on "FTA" , since it is not legal in the USA .. cant really discuss it here -- but lots of suppliers in canada
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    though i see you are really in the Netherlands, so i don't know whats over there
  4. Member SquirrelDip's Avatar
    Nov 2002
    Try http://www.maxxelectronics.net/xcart/home.php
    (If really in Canada...)
    Feb 2007
    On Earth!!
    Yep, doing intership here!
    Feb 2007
    On Earth!!
    Originally Posted by SquirrelDip
    any particular information for european viewer ?
  7. Member SquirrelDip's Avatar
    Nov 2002
    Do a google search for satellite locater or angle locater - to see what satellites you can see from your location. You need line of sight to the satellite...
    PM me an email address and I can give you some better information. I'm stepping out now and will be on tomorrow (maybe tonight) - it's a holiday today. in Alberta
    Feb 2007
    On Earth!!
    See PM please.
  9. Member Abbadon's Avatar
    Dec 2003
    Caribbean Sea
    Hi,
    Check for a piece of equipment called SkyStar 2, it is a PCI card that you can use with ProgDVB.
    You are going to need a Dish and LNB to scan for FTA.
    No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. ..
