    Feb 2007
    I was playing around with the on screen menu for this dvd player, and I clicked on some video setting for a different format. Now I can't see any video display from the player, not even the on screen menu. How do I undo my change or revert back to regular format ? I do hear the audio when I put in a DVD, hence the player is able to detect and play the DVD, only the video portion is somehow suppressed.
    Anyone seen this before or know how to help me with this issue ? Any comments appreciated.
    Jun 2006
    I have a tt-2600, see if there is a N/P button on your remote, if there is press it, this is for pal/ntsc.
    Also, check if there is a V-MODE on your remote, this is used to turn on and off progressive scan.
    Feb 2007
    SWBisbee, Thanks a lot for your suggestion. It worked - pressing the N/P button my remote. I don't have V-MODE button.
    Thanks once again - made my day
