I want a simple USB audio/video capture device to record VHS tapes to my computer.
I would like to be able to use the Capturing feature of VirtualDub, or another capturing program if I see fit. (I don't wanna be locked into one program, Like I am on my Creative Video Blaster Digital VCR PCI Card).
I was looking at: http://www.pricegrabber.com/search_techspecs_full.php/masterid=2237772
but I really have NO idea.
Please recommend some.
I'm on XP Pro, with 3.4ghz Pentium 4. 1gb RAM. 140gb Hard Drive.
Xenogear900@yahoo.com
I can recommend the Pinnacle Dazzle Platinum Device (DVC-170). It's a small external package that connects to a USB2 port. You feed it either composite video (three RCA connectors = video plus R/L audio) or a S-VHS. It does hardware encoding directly to mpeg2 (720x480 at bitrates you set ranging from 8 Mbps down). Hardware encoding means it doesn't load down your processor. I have a 3 GHz P4 and it uses less than 25% of the processor when capturing. You will probably have to use the included Pinnacle software to do the capturing, but once you have the mpeg2 file you can use whatever you want, and the Pinnacle installation doesn't seem to interfere with my other video software. I think it's about $80.
General Enquirey - Pinnacle Video Transfer USB 2.0 Capture Device
By kato2010 in forum Capturing and VCRReplies: 2Last Post: 11th Feb 2012, 06:53 -
Looking for a USB Video Capture Device I can work with in VB.Net
By Snakebyte1 in forum Capturing and VCRReplies: 0Last Post: 6th Oct 2011, 08:59 -
Can someone recommend a good USB style tuner device for me
By True Colors in forum Capturing and VCRReplies: 0Last Post: 31st Jan 2010, 15:12 -
Looking for a good USB-based video capture device
By Cyber Akuma in forum Capturing and VCRReplies: 10Last Post: 6th Jul 2009, 20:23 -
A Good USB Capture Device?
By hech54 in forum Capturing and VCRReplies: 5Last Post: 23rd Dec 2007, 03:23
