Hi there, I have a problem. I have downloaded some AVI files off the internet and burned them on CDs to play in my DVD Player on my TV... Some files worked, others didn't... i figured that the Compression Format used was different than what my DVD player supports...
I noticed how on some files there was a simple DivX Compression Format and some others had DixV 3 Low Compression Format... the latter weren't working on my DVD Player, so i figured that if i could change the Compression Format on my AVI files they would then work... the problem is that I do not know how to change that... I've searched the internet but there's no hints on that... can somebody here help me maybe?
thanks,
Lakyle
.avi to .VOB format - without changing size & quolity
By akakiami in forum Video ConversionReplies: 5Last Post: 19th Dec 2009, 11:48 -
Sequencing my DV from Analog to AVI to iMovie. Format? Compression?
By kiararden in forum Video ConversionReplies: 4Last Post: 2nd Oct 2009, 10:20 -
Black Thumbnails on .AVI files (XVID compression)
By $lamscaper in forum Video ConversionReplies: 1Last Post: 24th Oct 2008, 22:11 -
Best format to save AVI files on PC
By bpatters69 in forum Video ConversionReplies: 6Last Post: 31st Mar 2008, 08:31 -
Best compression format for AVI's
By Smallan in forum Video ConversionReplies: 2Last Post: 19th May 2007, 18:13
