Hi,
I have this DVD of a wedding which is a bit of a mess. What I need to do really is try to sort it out and reauthor it so I can put my own menu and chapters etc.
The files I have are:
Folder:VIDEO_RM DVD_REC.USR; PVR_TEMP.USR; VIDEO_RM; VIDEO_RM.BUP; VIDEO_RM.IFO
Folder:VIDEO_TS VIDEO_TS (Vob file); VIDEO_TS.BUP; VIDEO_TS.IFO; VTS_01_0.BUP; VTS_01_0.IFO; VTS-01_1 (VOB); VTS_01_2 (VOB); VTS_01_3 (VOB)
So basically I dont know what the VIDEO_RM folder is or what it contains. I have three VOB files which I believe contain the raw data for what I want.
Can anyone help? And/or suggest a useful program for me?
tmpgenc dvd author and add select add dvd video and choose the video_ts
and for the video_rm https://forum.videohelp.com/viewtopic.php?t=299589&highlight=videorm
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
Create DVD with TMPGEnc DVD Author 3 and not read on DVD Player
By Salutatous in forum Authoring (DVD)Replies: 1Last Post: 22nd May 2008, 11:22 -
Author 5.1 DVD
By Astrogirl in forum Authoring (DVD)Replies: 4Last Post: 7th Apr 2008, 16:43
