    Feb 2007
    Hello Friends,
    I would like to reauthor a DVD, where I want to remove certain video clips. I have the dvd ISO, so I used magic iso and simply remove the unwanted video files. This did not work . I was hoping if you someone can guide me (I am hoping the steps are simple), to remove the unwanted dvd video files - still preserve the main menu.
    Thank you.
  2. Member steveryan's Avatar
    Jan 2003
    Manchester
    If you want to remove extra features mount with Daemon Tools and use VobBlanker to remove. If you want to remove specific scenes then I can't help, but i'm sure somebody can.
    He's a liar and a murderer, and I say that with all due respect.
    Feb 2007
    Thank you for your reply. I tried your suggestion.. I think it worked.. However, i did not save the file back as an ISO. Can you help me on this also please
  4. Member steveryan's Avatar
    Jan 2003
    Manchester
    Burn the VIDEO_TS folder using ImgBurn.
    Feb 2007
    One more question ( I hope I am not pushing my luck). Can I disable/remove the menu link to the video file i want to remove. I am uisng DVD Shrink to idenitfy which is the menu I dont want...
  6. Member steveryan's Avatar
    Jan 2003
    Manchester
    Nov 2004
    Las Vegas
    The freeware method would be to use PgcEdit. Open your project, locate the menu you want to change, open the Menu Editor, select the button you want to disable, click "Button" on the menu, and then click the "Delete Button" entry.
    Feb 2007
    Perfect, It works.. Thank you all you help. I have at this for past three days.. You guidence helped me resolve this in few hours. Cheers.
