I am using the software VLC. I am using the capture function to capture what is on the screen. It says to "use Btw, CTRL key plus PRINTSCREEN key button combo to capture your screen to a file in windows". CTRL is the Control key. PRINTSCREEN is the PrtScn key.
PROBLEM: What is Btw?????
Thank you,
Bryan Kendall
I find it easier to use the 'Snapshot' function with VLC. Then you can save as many as you want to your 'My Pictures' folder. If you use PrtScn, you will have to save each one with a program like Paint before you can capture the next.
I have no idea what Btw means in that context. But you would hold down the CTRL key while hitting the PrtScn key.
DVD plays differently on VLC vs other software/hardware?
By PartyRambo in forum Authoring (DVD)Replies: 5Last Post: 31st Oct 2011, 03:29 -
How to capture/record stream videos using VLC 1.1.9
By 1234567 in forum Capturing and VCRReplies: 0Last Post: 15th May 2011, 08:52 -
Recommended dvd authoring software with manually chapter function...
By Conrad007 in forum Authoring (DVD)Replies: 14Last Post: 27th Feb 2011, 12:54 -
VLC Screen Capture
By DuBsTaR in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2008, 11:59 -
Freeware CD burning software with normalizing function req
By boing in forum AudioReplies: 2Last Post: 15th Sep 2007, 12:03
