  1. I just authored a DVD and want to burn it to 4 identical recorders simultaneously but always get a "end of track" error which happens at 100% of recording phase. The DVD is readable on the PC but not on the DVD player. I'm using Windows Vista, Taiyou Yuden 8x DVD-R, LITE-ON DVDRW SHW-160P6SPS0A, Nero Version: 7.7.5.1. The same error happens when I burn to 2 or 3 recorders simultaneously. Burning is only successful when burning to 1 recorder. Below is the log.
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    BUFE : 0
    Physical memory : 2047MB (2097151kB)
    Free physical memory: 1402MB (1436656kB)
    Memory in use : 56 %
    Uncached PFiles: 0x0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    18.2.2007
    UDF/ISO compilation
    6:50:53 AM #1 Text 0 File SCSIPTICommands.cpp, Line 411
    LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    6:50:53 AM #2 Text 0 File SCSIPTICommands.cpp, Line 411
    6:50:53 AM #3 Text 0 File SCSIPTICommands.cpp, Line 411
    6:50:53 AM #4 Text 0 File SCSIPTICommands.cpp, Line 411
    6:50:53 AM #5 Phase 112 File dlgbrnst.cpp, Line 1760
    DVD-Video files reallocation started
    6:50:53 AM #6 Phase 114 File dlgbrnst.cpp, Line 1760
    DVD-Video files reallocation completed (no file modified)
    6:50:53 AM #7 Text 0 File Isodoc.cpp, Line 6527
    UDF document burn settings
    Determine maximum speed : FALSE
    Simulate : TRUE
    Write : TRUE
    Finalize CD : TRUE
    Multisession : FALSE
    Burning mode : DAO
    Mode : 1
    UDF Mode : UDF/ISO bridge
    UDF Options : automatic
    UDF Revision : 1.02
    UDF Partition Type : physical
    ISO Level : 1 (Max. of 11 = 8 + 3 char)
    Character set : ISO 9660
    Joliet : FALSE
    Allow pathdepth more than 8 directories : TRUE
    Allow more than 255 characters in path : TRUE
    Write ISO9660 ;1 file extensions : TRUE
    6:50:53 AM #8 Phase 111 File dlgbrnst.cpp, Line 1760
    DVD-Video files sorted
    6:50:53 AM #9 ISO9660GEN -11 File Geniso.cpp, Line 3334
    First writeable address = 0 (0x00000000)
    6:50:53 AM #10 ISO9660GEN -11 File Geniso.cpp, Line 3334
    6:50:53 AM #11 Text 0 File Burncd.cpp, Line 3465
    Turn on Disc-At-Once, using DVD media
    6:50:53 AM #12 Text 0 File Burncd.cpp, Line 3465
    6:50:53 AM #13 Text 0 File Burncd.cpp, Line 3465
    6:50:53 AM #14 Text 0 File Burncd.cpp, Line 3465
    6:50:54 AM #15 Text 0 File DlgWaitCD.cpp, Line 306
    Last possible write address on media: 2298495 (510:46.45, 4489MB)
    Last address to be written: 2199503 (488:46.53, 4295MB)
    6:50:54 AM #16 Text 0 File DlgWaitCD.cpp, Line 318
    Write in overburning mode: NO (enabled: CD)
    6:50:54 AM #17 Text 0 File DlgWaitCD.cpp, Line 2912
    Recorder: LITE-ON DVDRW SHW-160P6S (6/1), Media type: DVD-R
    Disc Manufacturer: TYG02 -
    Disc Application Code: 64, Disc Physical Code: 193
    6:50:54 AM #18 Text 0 File DlgWaitCD.cpp, Line 490
    >>> Protocol of DlgWaitCD activities: <<<
    6:50:54 AM #19 Text 0 File DlgWaitCD.cpp, Line 306
    6:50:54 AM #20 Text 0 File DlgWaitCD.cpp, Line 318
    6:50:54 AM #21 Text 0 File DlgWaitCD.cpp, Line 2912
    Recorder: LITE-ON DVDRW SHW-160P6S (2/1), Media type: DVD-R
    6:50:54 AM #22 Text 0 File DlgWaitCD.cpp, Line 490
    6:50:54 AM #23 Text 0 File DlgWaitCD.cpp, Line 306
    6:50:54 AM #24 Text 0 File DlgWaitCD.cpp, Line 318
    6:50:54 AM #25 Text 0 File DlgWaitCD.cpp, Line 2912
    Recorder: LITE-ON DVDRW SHW-160P6S (0/1), Media type: DVD-R
    6:50:54 AM #26 Text 0 File DlgWaitCD.cpp, Line 490
    6:50:54 AM #27 Text 0 File DlgWaitCD.cpp, Line 306
    6:50:54 AM #28 Text 0 File DlgWaitCD.cpp, Line 318
    6:50:54 AM #29 Text 0 File DlgWaitCD.cpp, Line 2912
    Recorder: LITE-ON DVDRW SHW-160P6S (4/1), Media type: DVD-R
    6:50:54 AM #30 Text 0 File DlgWaitCD.cpp, Line 490
    6:50:54 AM #31 Text 0 File ThreadedTransferInterface.cpp, Line 823
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 ()
    2 indices, index0 (150) not provided
    original disc pos #0 + 2199504 (2199504) = #2199504/488:46.54
    relocatable, disc pos for caching/writing not required/ required
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2199504 blocks [J: LITE-ON DVDRW SHW-160P6S]
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2199504 blocks [L: LITE-ON DVDRW SHW-160P6S]
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2199504 blocks [N: LITE-ON DVDRW SHW-160P6S]
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2199504 blocks [P: LITE-ON DVDRW SHW-160P6S]
    6:50:54 AM #32 Text 0 File ThreadedTransferInterface.cpp, Line 1026
    Prepare [J: LITE-ON DVDRW SHW-160P6S] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1: Idx 0 Idx 1 Next Trk
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4504584192, ISRC ""
    DAO layout:
    ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
    0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
    0 | 1 | 0 | 0x41 | 2199504 | 0 | 0x00
    0 | 1 | 1 | 0x41 | 2199504 | 0 | 0x00
    2199504 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
    6:50:54 AM #33 Text 0 File ThreadedTransferInterface.cpp, Line 1026
    Prepare [L: LITE-ON DVDRW SHW-160P6S] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    DAO layout:
    6:50:54 AM #34 Text 0 File ThreadedTransferInterface.cpp, Line 1026
    Prepare [N: LITE-ON DVDRW SHW-160P6S] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    DAO layout:
    6:50:54 AM #35 Text 0 File ThreadedTransferInterface.cpp, Line 1026
    Prepare [P: LITE-ON DVDRW SHW-160P6S] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    DAO layout:
    6:50:54 AM #36 Text 0 File SCSIPTICommands.cpp, Line 209
    SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
    6:50:54 AM #37 Text 0 File SCSIPTICommands.cpp, Line 209
    6:50:54 AM #38 Text 0 File SCSIPTICommands.cpp, Line 209
    6:50:54 AM #39 Text 0 File SCSIPTICommands.cpp, Line 209
    6:50:54 AM #40 Phase 24 File dlgbrnst.cpp, Line 1760
    Caching of files started
    6:50:54 AM #41 Text 0 File Burncd.cpp, Line 4298
    Cache writing successful.
    6:50:54 AM #42 Phase 25 File dlgbrnst.cpp, Line 1760
    Caching of files completed
    6:50:54 AM #43 Phase 32 File dlgbrnst.cpp, Line 1760
    Simulation started at 4x (5,540 KB/s)
    6:50:54 AM #44 Text 0 File ThreadedTransferInterface.cpp, Line 2764
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    6:50:54 AM #45 Text 0 File DVDR.cpp, Line 3070
    Recording mode: Sequential Recording Mode
    6:50:54 AM #46 Text 0 File DVDR.cpp, Line 3226
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    6:50:54 AM #47 Text 0 File Cdrdrv.cpp, Line 9288
    ---- DVD Structure: Physical Format Information (00h) ----
    Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
    Disc Size: 120 mm, Maximum Rate: (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 26127F h
    End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
    Data in Burst Cutting Area (BCA) does not exist
    Start sector number of the current Border-Out: 0 h
    Start sector number of the next Border-In: 0 h
    Media Specific [16..63]:
    00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
    6:50:54 AM #48 Text 0 File DVDR.cpp, Line 3070
    6:50:54 AM #49 Text 0 File DVDR.cpp, Line 3226
    6:50:54 AM #50 Text 0 File Cdrdrv.cpp, Line 9288
    6:50:55 AM #51 Text 0 File DVDR.cpp, Line 3070
    6:50:55 AM #52 Text 0 File DVDR.cpp, Line 3226
    6:50:55 AM #53 Text 0 File Cdrdrv.cpp, Line 9288
    6:50:55 AM #54 Text 0 File DVDR.cpp, Line 3070
    6:50:55 AM #55 Text 0 File DVDR.cpp, Line 3226
    6:50:55 AM #56 Text 0 File Cdrdrv.cpp, Line 9288
    6:51:00 AM #57 Text 0 File Cdrdrv.cpp, Line 1303
    06:51:00.709 - P: LITE-ON DVDRW SHW-160P6S : Queue again later
    6:51:00 AM #58 Text 0 File Cdrdrv.cpp, Line 1303
    06:51:00.716 - N: LITE-ON DVDRW SHW-160P6S : Queue again later
    6:51:00 AM #59 Text 0 File Cdrdrv.cpp, Line 1303
    06:51:00.801 - L: LITE-ON DVDRW SHW-160P6S : Queue again later
    6:51:00 AM #60 Text 0 File Cdrdrv.cpp, Line 1303
    06:51:00.808 - J: LITE-ON DVDRW SHW-160P6S : Queue again later
    7:04:42 AM #61 SPTI -1037 File SCSIPassThrough.cpp, Line 179
    CdRom4: SCSIStatus(x02) WinError(0) NeroError(-1037)
    Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
    Sense Code: 0x63
    Sense Qual: 0x00
    CDB Data: 0x2A 00 00 21 8F C0 00 00 20 00 00 00
    Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 63
    Buffer x284790c0: Len x10000
    0x02 00 02 00 FD 00 00 00 01 D7 F0 01 80 8F 21 00
    0x00 80 00 00 20 00 00 00 00 80 00 00 30 00 00 00
    0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    7:04:42 AM #62 CDR -1037 File Writer.cpp, Line 301
    End of user area of this track
    7:04:45 AM #63 SPTI -1037 File SCSIPassThrough.cpp, Line 179
    CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1037)
    Sense Code: 0x63
    Sense Qual: 0x00
    Buffer x28489100: Len x10000
    0x02 00 02 00 1D 00 00 00 01 D7 F0 01 A0 8F 21 00
    7:04:45 AM #64 CDR -1037 File Writer.cpp, Line 301
    7:04:46 AM #65 SPTI -1037 File SCSIPassThrough.cpp, Line 179
    CdRom6: SCSIStatus(x02) WinError(0) NeroError(-1037)
    Sense Code: 0x63
    Sense Qual: 0x00
    7:04:46 AM #66 CDR -1037 File Writer.cpp, Line 301
    7:04:50 AM #67 SPTI -1037 File SCSIPassThrough.cpp, Line 179
    CdRom2: SCSIStatus(x02) WinError(0) NeroError(-1037)
    Sense Code: 0x63
    Sense Qual: 0x00
    7:04:50 AM #68 CDR -1037 File Writer.cpp, Line 301
    7:04:50 AM #69 Text 0 File DVDR.cpp, Line 3446
    EndDAO: Last written address was 2199487
    7:05:16 AM #70 Text 0 File DVDR.cpp, Line 3446
    7:05:22 AM #71 Text 0 File DVDR.cpp, Line 3446
    7:05:27 AM #72 Text 0 File DVDR.cpp, Line 3446
    7:05:33 AM #73 Phase 34 File dlgbrnst.cpp, Line 1760
    Simulation failed at 4x (5,540 KB/s)
    7:05:33 AM #74 Text 0 File SCSIPTICommands.cpp, Line 254
    SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
    7:05:35 AM #75 Text 0 File Cdrdrv.cpp, Line 10529
    DriveLocker: UnLockVolume completed
    7:05:35 AM #76 Text 0 File SCSIPTICommands.cpp, Line 254
    7:05:37 AM #77 Text 0 File Cdrdrv.cpp, Line 10529
    7:05:37 AM #78 Text 0 File SCSIPTICommands.cpp, Line 254
    7:05:39 AM #79 Text 0 File Cdrdrv.cpp, Line 10529
    7:05:39 AM #80 Text 0 File SCSIPTICommands.cpp, Line 254
    7:05:41 AM #81 Text 0 File Cdrdrv.cpp, Line 10529
    7:05:41 AM #82 Text 0 File SCSIPTICommands.cpp, Line 411
    UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    7:05:41 AM #83 Text 0 File SCSIPTICommands.cpp, Line 411
    7:05:41 AM #84 Text 0 File SCSIPTICommands.cpp, Line 411
    7:05:41 AM #85 Text 0 File SCSIPTICommands.cpp, Line 411
  2. I uninstall Nero 7.7.5.1 and install Nero 7.5.7.0 =, the error disappears
