Hello,
I captured a made-for-TV movie from film today. It seemed to have soft focus.
Other threads here say the TV is "soft focus" compared to my monitor. So things should look naturally sharper on the TV, right?
I can use the ATI software to sharpen as I capture, or other software afterwards.
Before I go through the act of authoring a disc, should I bother sharpening if the source is soft to begin with?
If the image is already soft, then if anything it will look softer on your TV. A softer playback device will not sharpen a soft image.
If the focus is deliberately soft (the "Sybil Shepard" look) then there isn't a lot you can do. Sharpening will more than likely do little more than make any noise in the image more apparent, and make edges halo.Read my blog here.
Well, that's not exactly right either.Originally Posted by guns1inger
He's referring to optical illusions. It's true that a softer image will appear sharp when viewed on a device incapable of showing it to be sharper. Nothing to compare it to, going from channel to channel.Want my help? Ask here! (not via PM!)
MPC grabbing focus - don't want
By Monarch1st in forum Software PlayingReplies: 3Last Post: 17th Feb 2012, 13:07 -
Cannot Focus or Motion Blurrrr??
By Compo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 18th Aug 2011, 17:53 -
Focus question
By zsuppguy in forum Newbie / General discussionsReplies: 9Last Post: 12th Jan 2010, 17:40 -
Upgrade Focus FS-4 to HD
By tennant in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 24th Feb 2009, 16:49 -
Tips on Manual Focus
By B-Twien Bytes in forum Newbie / General discussionsReplies: 7Last Post: 21st Jul 2007, 08:40
