First..strokes to Stinky for all his work!
I installed the ATI macrovision patch per the instructions that came with the patch. Sadly it didn't work.
I then did a search for the renamed original file "ATIVMDXX.ORI".
It was in the x:\windows\system32\drivers directory along with the patched version.
I then did a search for "ATIVMDXX.*". It turns out there was another copy of the old file in the x:\windows\system directory. I copied the patched file from the x:\windows\system32\drivers to the x:\windows\system directory, rebooted and wha-la!!
Hope this helps somebody.
I didnt code it to look in \system only in \system32
I only had a way to test it on NT/2K/XP ... not 95/98
so your right - I didnt know if it worked on those systems ... I could update the code to search in \system also (maybe next update)
-stinky
http://stinky.dosrules.com
VHS to pc patch cable
By Dr.Gee in forum Newbie / General discussionsReplies: 11Last Post: 7th Apr 2011, 07:43 -
How to patch 352x480 MPEG-2 to 720x480
By moxiecat in forum Video ConversionReplies: 1Last Post: 1st Mar 2010, 13:43 -
Removing PowerDVD 8 Patch Notice
By J8son in forum Software PlayingReplies: 2Last Post: 4th Jan 2009, 20:52 -
Background/ Splash screen patch in the UK
By stavdav in forum DVD & Blu-ray PlayersReplies: 3Last Post: 30th Nov 2007, 10:13 -
ProjectX - possible to patch?
By netmask56 in forum DVB / IPTVReplies: 1Last Post: 21st May 2007, 00:18
