hi, as subject says, just looking for a reliable small program that only makes dvd burner/software refion free, and nothing else.
Is there any that would be recommended?
thanks
Results 1 to 11 of 11
For most DVD readers/writers, there is some kind of hacked firmware available that makes it region free. Every make and model has its own firmware. There's no G P "make DVD reader region free" software.
DVD43 and AnyDVD doesn't make your hardware region free, but allows you to read "wrong region" discs anyway.
/Mats -
lets just say the player is locked to one region, the software will allow to play another region?
I want firmware to be last option if possible.
thanks. -
yeah, i checked those tools out before i posted, and the ones that do only region-free(almost)
dvd killer
remote selector
dvd43
but the comments said there was problems etc...thats why i asked if there were reliable ones.
would dvd43 be the best of them 3?
thanks again. -
Originally Posted by mats.hogberg
/Mats -
I've never had a problem with DVD REGION KILLER. What dvd burner model do you have? Remember now you'll have to make your dvd region free by using hacked firmware and use a program like DVD REGION KILLER for your operating system. As mentioned ANYDVD isn't free.
you will NEED to use a hacked firmware for your PIONEER 109 drive to make it become region free.
http://tdb.rpc1.org/#DVR109 -
Just to add...
If you intend on making back-ups of any of your DVDs from whatever region, you don't need to make your DVD drive region free. All of the software that makes back-up copies will produce a region free disc that can be played on the drive.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
Is there any free reliable tool to convert the .mov to MEPG?
By coody in forum Video ConversionReplies: 1Last Post: 12th Dec 2008, 21:05 -
Klipsch CS-500, need to make region free / code free / zone free
By Trialsman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 14:16 -
Need Reliable MPEG-2 Editing Software ...
By cyberboy in forum EditingReplies: 2Last Post: 15th Nov 2008, 02:04 -
Any free, good, reliable software for video streaming capture?
By rob1974 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2007, 16:26
