Hey i need some help and hope this is the right place to get it. I tried to searce the forums but diden't find anything about this.
I have tried to follow thise guides, but the only result I have got was a black screen with audio
www.videohelp.com/tmpgenc.htm
www.videohelp.com/divxtovcd.htm
I would like to make a vcd, with video and audio, in PAL. If it is posible i would like to have subtitle on the vcd to.
I dont know how much information you need, so i give you all i have.
I have a avi file
Frame size 640x352
Length 61783 frames (42,56 min)
Fps: 23,976
Audio file is wmv i used virtuldub to get that.
Hope that one of you will take some of your time to help me.
Results 1 to 9 of 9
You're probably missing the video codec. Load the AVI in GSpot, and post a screen shot.
/Mats -
dont know how to upload screen shot
But i can see the avi on my computer, i just want to convert the avi file so i can burn it on a cd and wacth it on my dvd player.
that is just way to small to read, you know how i can make it bigger?
just found out. -
Since your Xvid has VBR audio, if you used that with TMPGEnc, you would likely have sync and other problems. But do you mean you used VirtualDub to extract the audio to a WAV format with full audio processing? That should cure the sync problem. TMPGEnc can't handle VBR audio.
Do you get a black screen with other MPEG-1 or MPEG-2 videos? If so, that sounds like a overlay problem and not a problem with your video. I don't see any obvious problems with the TMPGEnc converted video. You could try playing it back with VLC Media Player. It has overlay adjustments. -
Originally Posted by redwudz
And I just tried VLC Media Player and I could see the video and hear the audio, so that is fine.
But do that mean that I can burn the mpg file to a cd and get a vcd or what has to be done before that will work?
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 09:30 -
Black Screen?
By Hal05154 in forum Video Streaming DownloadingReplies: 0Last Post: 11th Jul 2009, 06:57 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 17:36 -
Black Screen
By jansz in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2008, 11:03 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 11:16
