look for good avi split program (over 3gb files)
i just try with "Easy Video Splitter" and the splited files created with no sound.
any body can give me name of good splitting avi file program?
thanks
Results 1 to 10 of 10
Avoid all apps with "easy" as part of its name
Try VirtualDub.
/Mats -
How long (time) is it?
You probably can squeeze it down with AutoGK to DivX/XviD.
/Mats -
i don't know how long is that becouse i canceled in the beginning, what should i do?
do you have any guide for this? -
Split file with Winrar.
Set in winrar compression method "Store" and set split to volumes
Originally Posted by roma_turok
Program to split .mov files without re-encoding
By Guest in forum EditingReplies: 5Last Post: 21st Jul 2010, 20:09 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 22:42 -
Simple issue, cannot find program to do it..need to split AVI with a FF
By serpa4 in forum EditingReplies: 17Last Post: 4th Nov 2009, 23:19 -
Split .tp files, which program?
By Strawjellybelly in forum EditingReplies: 2Last Post: 29th Jan 2009, 11:04 -
Good Program / codec to encode Flash Vp6 files to avi? Audio is Out of Sync
By hypnoticpimp in forum Video Streaming DownloadingReplies: 1Last Post: 14th Jul 2008, 00:25
