Hi,
Can svcd2dvd handle a 14.5 gig hd dvd film in ext ts?
Cheers
John
Depends what the audio/video streams are.
They are direct rip from Sky Film HD channels, not sure if thats any use to you.
Thanks -
ok. But is it MPEG2, H264? AC3, ACC? What is the container? TS, AVI?.... Open the file in GSpot and attach the resultant screenshot. BTW how are you directly ripping from SkyHD? Via the box?
the files are h264 and now the problem i am getting is after adding .ts file and starting the process of converting the .ts file after about 30 secs i get error msg ffmpeg.exe has stopped working. I am running vista home premium 64bit edition
Cheers
John
This is as uch info i can get on the .ts file
PID Tree:
PAT Ver: 1 TS ID: 0x0001
Program : 3 PMT PID: 0x0030
0x0031 : H.264/AVC Video (as defined in ITU-T Rec. H.264 | ISO/IEC 14496-10 Video)
0x0034 : AC-3 (ATSC A/53B audio)
PID List:
Found PID: 0000: PAT Ver: 1 TS ID: 0x0001
Found PID: 0030: Program : 3
Found PID: 0031: H.264/AVC Video (as defined in ITU-T Rec. H.264 | ISO/IEC 14496-10 Video)
Found PID: 0034: AC-3 (ATSC A/53B audio)
Found PID: 1FFE: -
H264 is the problem:
https://forum.videohelp.com/viewtopic.php?p=1647265&highlight=h264#1647265Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
Capturing films from camcorder and then burning to DVD
By peterlouisbrown in forum Capturing and VCRReplies: 3Last Post: 13th Jul 2011, 11:07 -
Films onto disc
By Pumkinhead in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2010, 06:00 -
I want to be able to burn these films to DVD, with their subtitles.
By KKPHM in forum SubtitleReplies: 15Last Post: 17th Mar 2010, 13:49 -
Hello! How to convert my films to DVD?
By breng60 in forum Newbie / General discussionsReplies: 5Last Post: 1st Jun 2009, 12:01
