When is it best to print CD/DVD Labels?
Before or after the data is burn onto the disc
Results 1 to 11 of 11
Always print after you first burn to the CD/DVD disc ... or in other words ... burn first then print.
As for printing I suggest using one of the Casio Printers: CLICK HERE
A friend of mine has the Casio CW-75 and it works really well.
He uses the "shiny silver" Taiyo Yuden DVD-R discs from RIMA.COM and they also carry "shiny silver" Taiyo Yuden CD-R media.
Granted this type of printer is really only good at text and maybe a very simple "graphic" but it looks clean and professional and most importantly since it is a thermal printer the ink will NOT come off from rubbing or normal disc handling etc.
Burn first .... print second ....
Reason
If your burn should fail for some reason you won't have wasted time and money (ink) on the printing process ...
I have on occassions printed the disk before burning ... usually because i was burning in one pc whilst printing from another and i needed to cut the time factor involved with burn first ... print second .... there is no reason other than the one above for doing it that way .... burn reliability is the same regardless of whether the disk is printed first or not -
Burn first, print second.
If you print and burn right away the ink will crack on the DVD. Try it. The ink dries too fast. -
I burn what I need , then print. Normally do batches of around 10-15 discs. Then print and store in cases.
Good Luck -
Originally Posted by psx_pirate
Read what videobread said again
Burn, test, then print. I try to let them dry overnight.
If you are in a time crunch and want to experiment with your new printer, let the ink dry, for say 24 hours, before burning. -
If you are on a time crunch, what difference does it make as to what order your do them in. You still have to let ink dry. I wouldn't want wet ink on a very hi speed rotating disc being thrown around inside the my dvd burner. My advise is always print direct to disc, don't use labels.
Question about CD/DVD labels
By tcory in forum Newbie / General discussionsReplies: 10Last Post: 12th Mar 2011, 11:08 -
DVD labels
By Ogilvy in forum MediaReplies: 18Last Post: 19th Dec 2009, 22:37 -
To print labels
By mis3 in forum MediaReplies: 9Last Post: 23rd Dec 2007, 09:27 -
CD / DVD Labels - Which ones should I get?
By jcm0320 in forum MediaReplies: 4Last Post: 15th Dec 2007, 22:01 -
CD / DVD Labels
By wesmoc in forum Newbie / General discussionsReplies: 6Last Post: 7th Jul 2007, 08:42
