i am trying out the trial version and i am trying to get my movie to eventually play on a dvd player but when i click the make movie option and burn to dvd option, it says sony dvd architect does not apear to be installed. i didn't know i had to have dvd architect too. all i'm trying to to is capture, edit, save my movie dvd format and burn it on a dvd to play on a dvd player. plase help!
DVD Architect is used for authoring - this is where the VOB, IFO and BUP files you see on any DVD are created, along with designing the menus etc.
See if there's a way where you can ouput your project to DVD compliant MPEG files. These will be either elementary streams (audio.wav or audio.ac3 or audio.mp2 - depending on which audio format you go for, and video.m2v) or a system stream (footage.mpg - containing both audio and video in one file).
From there, you can author using your chosen authoring application.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
thanks for your reply. i'm still confused, i thought vegas platinm could be used to capture, edit and save to dvd format (mpeg2) so it can be burned to dvd to be played on dvd players. how can i go about doing this using vegas platinum?
if i use dvd architect studio, it allows me to create menues like the ones in commercial dvd movies and create scene selections right? -
I'm using the trial version to see if its worth buying. i just looked at the manual and it doesn't say how i can save it to mpeg2 (dvd) format. all i see is how to save for vcd or cd which i don't want. i used to use windows media to capture and edit and avi converter to convert to dvd. thought this would be more straight farward.
thanks -
I haven't used Movie Studio, but I do use Vegas, it's big brother. In Vegas you output video via File -> Render As, and set up compression etc from there.
I would start here : http://www.sonymediasoftware.com/download/step2.asp?did=684
and download the two quickstart guides. They are small .pdf files, and should cover the basics.Read my blog here.
IMHO, VMS Platinum is incredible.Originally Posted by Ade007
I suggest you visite the Sony VMS Forum where lots of VMS users can give advice. Also, you'll probably find plenty of answers to many of your questions:
http://www.sonymediasoftware.com/forums/ShowTopics.asp?ForumID=12
Attempting to create DVD from Sony Vegas Movie Studio 9 Platinum...
By Greg / MO in forum Authoring (DVD)Replies: 6Last Post: 7th Aug 2013, 13:37 -
Premiere Elements 9 or Sony Vegas Movie Studio HD Platinum 10 Suite?
By HoosierGuy in forum EditingReplies: 37Last Post: 26th Feb 2011, 01:55 -
Does Sony Vegas Movie Studio HD Platinum 10 do 60fps?
By vid83 in forum EditingReplies: 13Last Post: 7th Feb 2011, 19:33 -
How to edit overmodulated audio in sony vegas movie studio platinum 9
By floriday_girl in forum EditingReplies: 1Last Post: 13th Sep 2010, 09:59 -
SONY Vegas Movie Studio Platinum 8.0
By pcanaveral in forum EditingReplies: 4Last Post: 13th Oct 2007, 23:38
