Hello
I use ConvertXToDVD to convert my AVI files frequently. I would like to add a proper Menu after the conversion as the Menu feature is pretty poor in the above sw, though the output quality seems to be pretty good.
So which tool can be used?
Please help.
Thank you.
Results 1 to 9 of 9
আমি বাংলায় গান গাই
Tmpgenc DVD Author - use the Add Video function - simple and easy
DVD Lab Pro - import the VOBs, demux and author - complex and powerful
GUIForDVDAuthor - you may have to demux first - sits somewhere in betweenRead my blog here.
Easy to use, but not the fanciest menus, would be TMPGEnc DVD Author. I still have the 1.6 version. For more quality, and better menus options, maybe DVD-Lab Pro. Not cheap though.
You can also use some freeware programs, like DVDAuthorgui or GUI for dvdauthor. They require you to make up your menu graphics using other programs that may be a little difficult to learn, but you can do every bit as good as a commercial DVD with enough time and experience.
EDIT: guns1inger, you out typed me again.
That's unfair. I'm ready to sleep and you are probably wide awake. Damn time difference. What is it, afternoon there?
Sorry guns1inger, what does it mean exactly?Originally Posted by guns1inger
Thank you for your opinion. So it seems that that both of you are not recommending any of the three programs that I mentioned and if I can afford I should go for DVD Lab Pro- right?
Sorry, no idea about dmuxing....I am rather new in this business.
আমি বাংলায় গান গাই -
Reds and I seen to post to the same thread almost identical answers on a regular basis - today I got in first. Just a little fun, and completely off topic.
I don't actually see any programs mentioned in your post, other than ConvertxtoDVD.
The advantage to three that we have mentions is that none of them will try to re-encode you video. Some other so-called authoring tools will. These include things like NeroVision.
Demuxing, or De-Multiplexing, is the process of extracting the video and audio data as separate streams of information. Most higher end authoring tools prefer to work with elementary, or separate video and audio streams, and to bring them back together when authoring. ConvertxtoDVD has already authored, so you have to undo this last step to get source ready to work with. DVD Lab Pro will certianly accept VOBs without demuxing, but this can often lead to unexpected behaviour.
PgcDemux or Rejig are two free, easy to use tools to achieve this before authoring, or DVD Lab Pro will do it for you on import.Read my blog here.
I don't know how ConvertXToDVD creates the vob files (SingleVTS/MultiVTS and i.e if several titles are 'stitched' in one vob file).
If there is only one title in one set of vob files, you can use them without demux by just renaming them to mpg (and join with copy/b if necessary see: http://download.videohelp.com/gfd/Help/RawMaterial.html ) Maybe vob2mpeg can also deal with multiple titles in one vob.
If GfD is used in 'dvdauthor mode', there is no need to demux the files.GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Thank you Borax and Guns1nger
This thread is basically an add on to this thread of mine: https://forum.videohelp.com/viewtopic.php?p=1659918#1659918
So those who would like to share their valuable input, I request them to pay visit to the other thread too. Guns1nger has benn helping me in that thread too, so I thank him specially for that.আমি বাংলায় গান গাই -
ConvertXtoDVD is a simple beastie - one VTS per title. Can have up to two audio tracks and one (or more ?) subtitle track per title.
Read my blog here.
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 01:50 -
dvd player +dvix+usb with external 160GB external HD problem...
By spidermen in forum Newbie / General discussionsReplies: 14Last Post: 14th Oct 2008, 19:45 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
DVD Lab "the subpicture of menu 1 is created from copy of external fil
By BeachNut in forum Authoring (DVD)Replies: 4Last Post: 26th Jan 2008, 08:05 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
